Virtusa
Last activity: 27 Jan 2017 0:46 EST
Issue editing the data table instances
We are getting Array index out of bound exception while trying to edit or delete some of the instances of a data table. Can anyone provide info on reason we are getting this error and the solution for this?
Likes (2)
Preethi Ageer Vijekanth Moorthy -
We will not be able to delete rows from datatable having entries >1000 or 950+.
That is because of url length restriction (as we use 'get')
You should be able to edit them using the excel (import/export ).
or try editing param.MaxRecords in ListEditorSettings, which was set to 1000 by default.
Can you post the stack trace from the log?
Virtusa
We have only 60 instances in the data table
Here is the stack trace
java.lang.ArrayIndexOutOfBoundsException: 0
at com.pega.pegarules.data.internal.access.CompressImpl.isCompressed(CompressImpl.java:239)
at com.pega.pegarules.data.internal.clipboard.StorageStreamCommonImpl.inflateStream(StorageStreamCommonImpl.java:624)
at com.pega.pegarules.data.internal.access.PageDatabaseMapperImpl.populatePageOrStringMapFromStreamColumn(PageDatabaseMapperImpl.java:2148)
at com.pega.pegarules.data.internal.access.PageDatabaseMapperImpl.createPageFromResultSet(PageDatabaseMapperImpl.java:462)
at com.pega.pegarules.data.internal.access.Opener.getResultFromResultSet(Opener.java:884)
at com.pega.pegarules.data.internal.access.Opener.openData(Opener.java:702)
at com.pega.pegarules.data.internal.access.Opener.openData(Opener.java:406)
at com.pega.pegarules.data.internal.access.DatabaseImpl.open(DatabaseImpl.java:4597)
at com.pegarules.generated.activity.ra_action_review_ce0aac03c978919a7a5a8ce38101e1fc.step5_circum0(ra_action_review_ce0aac03c978919a7a5a8ce38101e1fc.java:710)
at com.pegarules.generated.activity.ra_action_review_ce0aac03c978919a7a5a8ce38101e1fc.perform(ra_action_review_ce0aac03c978919a7a5a8ce38101e1fc.java:146)
at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3098)
at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:617)
at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.runActivitiesAlt(PRThreadImpl.java:601)
at com.pega.pegarules.session.internal.engineinterface.service.HttpAPI.runActivities(HttpAPI.java:2841)
at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequestInner(EngineAPI.java:394)
at sun.reflect.GeneratedMethodAccessor53.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:601)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1092)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:771)
at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequest(EngineAPI.java:328)
at com.pega.pegarules.session.internal.engineinterface.service.HttpAPI.invoke(HttpAPI.java:722)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._invokeEngine_privact(EngineImpl.java:312)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:263)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:240)
at com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngineInner(JNDIEnvironment.java:277)
at com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngine(JNDIEnvironment.java:222)
at com.pega.pegarules.web.impl.WebStandardImpl.makeEtierRequest(WebStandardImpl.java:400)
at com.pega.pegarules.web.impl.WebStandardImpl.doPost(WebStandardImpl.java:278)
at sun.reflect.GeneratedMethodAccessor52.invoke(Unknown Source)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:349)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:390)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:439)
at com.pega.pegarules.internal.web.servlet.WebStandardBoot.doPost(WebStandardBoot.java:118)
at com.pega.pegarules.internal.web.servlet.WebStandardBoot.doGet(WebStandardBoot.java:89)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:621)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:728)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:99)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:953)
at org.apache.catalina.valves.RemoteIpValve.invoke(RemoteIpValve.java:680)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1023)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:589)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:312)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:722)
This looks like a similar issue based on your stack trace, kindly look into the article over here.
Regards
Mahesh
Blue Rose Technologies GmbH
BE
Hi ,
Please have a look on the below link :
Thanks.
Virtusa
Thanks for your quick reply. Data table Edit in excel is not working for my app. We are using 6.3.1. Any info on that. We have tried the approach in below article but didn't work.
https://community.pega.com/support/support-articles/edit-excel-data-tables-not-working-0
Hi Zeba,
Kindly look into this article and try this as its the same 6.3.1 environment.
https://community.pega.com/support/support-articles/unable-edit-data-tables-sip-631
Regards
Mahesh
Virtusa
Hi Mahesh,
Thanks for your inputs. I have checked this article but the issue is in all environments so we can't delete and re insert the records at the DB end since its already in prod. From the data table, the edit in excel is not working. So I am trying to fix that 1st. Any ideas regarding the issue with edit in excel option of data tables?..I tried the approach given in article(https://community.pega.com/support/support-articles/edit-excel-data-tables-not-working-0) but edit in excel still doesn't work
