    Confidential
Last activity: 23 Aug 2018 19:03 EDT
Interrogation failing with error - Memory corruption
I've recently started the Openspan 8.0 training and I'm facing this issue during interrogation of the sample ( CRM ) application provided with Openspan training package. I'm using a windows 10 VM.
While clicking on Start Interrogation, system is generating an exception and the application is not launched. Exception is :
"Attempted to read or write protected memory. This is often an indication that other memory is corrupt."
If I go to the app directory and manually launch the application by clicking on CRM.exe file, it runs perfectly. If I change the target value of .os file to point to a different application, I'm able to launch that new application. But this application is not launching and I'm not able to complete the interrogation.
Details of exception are --
1) Exception Information
Exception Type: System.AccessViolationException
Message: "Attempted to read or write protected memory. This is often an indication that other memory is corrupt."
Data: IDictionary (System.Collections.ListDictionaryInternal) with 0 items
TargetSite: Boolean StartProcessInjected(System.String, System.String, System.String, IntPtr, Boolean, System.String, System.String, UInt32 ByRef, IntPtr ByRef)
HelpLink: NULL
Source: "OpenSpan.NativeInterop"
HResult: -2147467261
StackTrace Information
at OpenSpan.Interop.ScoutInterop.StartProcessInjected(String processPath, String arguments, String workingDirectory, IntPtr hResponseWnd, Boolean resumeSuspendedProcess, String remotingQueueName, String ignoreProcessNames, UInt32& pPid, IntPtr& phMainThread)
at OpenSpan.Adapters.Windows.WindowsProcess.Start(WindowsProcessStartMethod method, String path, String args, String dir, String target, Int32 timeout)
at OpenSpan.Adapters.Windows.WindowsAdapterBase.StartProcess(WindowsProcessStartMethod method, String path, String args, String dir, String target, Int32 timeout, Boolean hookChildProcesses, IWindowsProcess& process)
at OpenSpan.Adapters.Windows.WindowsAdapterBase.StartProcess(WindowsProcessStartMethod method, String path, String args, String dir, String target, Int32 timeout, IWindowsProcess& process)
at OpenSpan.Adapters.Windows.WindowsAdapter.StartAdapter()
at OpenSpan.Adapters.Adapter.HandlePerformStart(Object sender, CancelEventArgs e)
at OpenSpan.Design.DesignComponentCommon.OnPerformStart()
at OpenSpan.Design.DesignComponentCommon.Start()
at OpenSpan.Design.DesignComponent.Start()
at OpenSpan.Adapters.Design.InterrogationService.StartInterrogation()
at OpenSpan.Adapters.Windows.Design.WindowsInterrogationService.StartInterrogation()
at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md, Object[] args, Object server, Object[]& outArgs)
at System.Runtime.Remoting.Messaging.StackBuilderSink.AsyncProcessMessage(IMessage msg, IMessageSink replySink)
at System.Runtime.Remoting.Proxies.AgileAsyncWorkerItem.ThreadPoolCallBack(Object o)
at System.Threading.QueueUserWorkItemCallback.WaitCallback_Context(Object state)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem()
at System.Threading.ThreadPoolWorkQueue.Dispatch()
at System.Threading._ThreadPoolWaitCallback.PerformWaitCallback()
