Infosys
Infosys
Infosys
Posted: Feb 8, 2019
Last activity: Feb 11, 2019
Last activity: 11 Feb 2019 0:37 EST
Interaction Framework usage guidelines
I want to know when should interaction framework to be used?
Can I use in below scenarios:
1. If process interact with one application
2. If process interacts with more than 1 application
3. Is it mandatory to use interaction framework for any process irrespective of process flow
Yes, you can use it regardless of number of applications and at the same time it is not mandatory for use. It all depends on your use case and what you are trying to achieve using Interaction Framework.
Please take a look on the overview here: http://help.openspan.com/80/Interaction_Framework/Interaction_Framework_Overview.htm
And also on the attached PDF demonstrating one of its possible usages.
