TCS
Last activity: 23 Aug 2018 19:06 EDT
Need Sample Solution for Interaction Framework
Anyone here can share the Sample Solution for the Interaction Framework.
Chirag Patel
Updated: 21 Jun 2017 8:52 EDT
Tata consultancy services
Hi
Do we have any Interaction Framework document with web adaptors ?
Thanks & Regards
Chettiannan.P
The interaction framework is not specific to adapters. There is nothing different about it with regards to which type of adapter you are using (or not using any at all).
Thank you.
Regards
Chettiannan.p
I try to do some sample with Interaction Framework concept but I am getting issues in between. I have attached error snapshots. Please check and let me know if you need more information's on this. I am not able to upload the solution in this.
I have fixed this issue myself. Thanks
So glad to hear that you have resolved this on your own! Would love for you to share how you resolved this so that if others have the same question in the future, they will also know how to fix.
Thanks!
interaction xml has some duplicate records. Just i removed those duplicates and it fixed the issue.
I am not familiar with those errors specifically. It seems as though you have something corrupted or missing from your project.
Chirag,
It's recommended to create the solution from sratch to get the understanding of all the inner workings and details of the interaction framework.
I have attached a PDF document that walks your through creating your first Interaction Framework project and also provides details of how the framework works with each step.
Please have a look.
