Brown Advisory
Last activity: 3 Mar 2017 2:09 EST
Integration with office 365 and setting a Out of Office message.
Hi ,
It is possible in pega to set the "Out of Office" message by integration with Outlook.
Raghu
Pega Sales is having Outlook integration(it requires exe) where the calendar and Outlook Inbox, etc.. can be sync.
Hi Palagani,
Please refer the attached document for office 365 intergration and it will provide you the guidance for your query.
Note: Article content has been edited due to security information.
Sudhish OP
Brown Advisory
Thanks Sandhish for your prompt reply. i will have a look into this.
Brown Advisory
Hi Sudhish,
I am unable to see the oAuth Provider in Pega 7.1.7. Is this rule type available in 7.1 ?
Raghu
Hi Raghu,
No. It is available from 7.2 PRPC
https://docs-previous.pega.com/data-and-integration/accessing-pega-api-using-oauth-20
Brown Advisory
Hi Sudhish,
I have tried the approach given by you in the attached document. i am getting the error message PFA attached error message. I have seen the rest connector given by you, but there are no input request parameters. Do we need to send any request parameters?
Much appreciated your response and support on this.
Raghu
Hi Raghu,
Can you please refer below links (seems to be related) and see it helps.
Brown Advisory
Thanks Sudhish,
i will check this and will get back to you if i need any help on this.
Raghu
