Virtusa
Last activity: 1 Nov 2017 9:50 EDT
Integer mode property Behaving weird after posting value to clipboard-- the value entered is changing when the max length is 10
Hi Team,
we have a use case like need to have a property which need to accept 10 digits , for this one i created a integer property and made max length of 10 , when am using it in section after entering 10 digits its changing the value entered in that field. tried with lot many values to check when the change is happening 2,147,483,647 till this value input is not changing above this value is changing to negative value or to different value.
Will this is of Integer range issue?
Thanks & Regards
Vikas G
