Installing Pega 8.6: server log show no error, but web page is not accessible
I'm trying to install Pega 8.6 on tomcat server using Postgres as database. following the pega 8.6 installation guide using tomcat and postgres. after deploying the war, server show no error on log, but web page is inaccessible. please advice what should I do.
My Installation condition:
- CPU 4 core, memory 14 Gb, OS centos 7
- OpenJDK 1.8
- Tomcat 9
- Postgres 11
catalina log:
- OpenJDK 1.8
- Tomcat 9
- Postgres 11
catalina log:
21-Jul-2022 10:31:36.703 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version name: Apache Tomcat/9.0.64
21-Jul-2022 10:31:36.756 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: Jun 2 2022 19:08:46 UTC
21-Jul-2022 10:31:36.756 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version number: Proprietary information hidden
21-Jul-2022 10:31:36.756 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Linux
21-Jul-2022 10:31:36.757 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 3.10.0-1160.71.1.el7.x86_64
21-Jul-2022 10:31:36.757 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: amd64
21-Jul-2022 10:31:36.757 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home: /usr/lib/jvm/java-1.8.0-openjdk- Proprietary information hidden.b09-1.el7_9.x86_64/jre
21-Jul-2022 10:31:36.757 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 1.8.0_332-b09
21-Jul-2022 10:31:36.757 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: Red Hat, Inc.
21-Jul-2022 10:31:36.757 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: /opt/tomcat
21-Jul-2022 10:31:36.758 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: /opt/tomcat
21-Jul-2022 10:31:36.761 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=/opt/tomcat/conf/logging.properties
21-Jul-2022 10:31:36.761 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
21-Jul-2022 10:31:36.761 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xms4096m
21-Jul-2022 10:31:36.761 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xmx8192m
21-Jul-2022 10:31:36.762 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.security.egd=file:///dev/urandom
21-Jul-2022 10:31:36.762 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.awt.headless=true
21-Jul-2022 10:31:36.762 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -DNodeType=universal
21-Jul-2022 10:31:36.762 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djdk.tls.ephemeralDHKeySize=2048
21-Jul-2022 10:31:36.762 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.protocol.handler.pkgs=org.apache.catalina.webresources
21-Jul-2022 10:31:36.762 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dorg.apache.catalina.security.SecurityListener.UMASK=0027
21-Jul-2022 10:31:36.762 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dignore.endorsed.dirs=
21-Jul-2022 10:31:36.763 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=/opt/tomcat
21-Jul-2022 10:31:36.763 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=/opt/tomcat
21-Jul-2022 10:31:36.763 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=/opt/tomcat/temp
21-Jul-2022 10:31:36.772 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent The Apache Tomcat Native library which allows using OpenSSL was not found on the java.library.path: [/usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib]
21-Jul-2022 10:31:37.414 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8080"]
21-Jul-2022 10:31:37.477 INFO [main] org.apache.catalina.startup.Catalina.load Server initialization in [1039] milliseconds
21-Jul-2022 10:31:37.544 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service [Catalina]
21-Jul-2022 10:31:37.544 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet engine: [Apache Tomcat/9.0.64]
21-Jul-2022 10:31:37.587 INFO [main] org.apache.catalina.startup.HostConfig.deployWAR Deploying web application archive [/opt/tomcat/webapps/prweb.war]
21-Jul-2022 10:31:38.371 INFO [main] java.util.ArrayList.forEach Name = PRFileStore Ignoring unknown property: value of "Database-based File Access" for "description" property
21-Jul-2022 10:31:38.412 INFO [main] java.util.ArrayList.forEach Name = AdminPegaRULES Ignoring unknown property: value of "PegaRULES Admin datasource" for "description" property
21-Jul-2022 10:31:38.444 INFO [main] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
21-Jul-2022 10:31:38.546 INFO [main] com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource. Loading bootstrap properties from /prbootstrap.properties
21-Jul-2022 10:31:38.548 INFO [main] com.pega.pegarules.internal.bootstrap.SettingReaderJNDI. Could not find java:comp/env/prbootstrap/ in the local JNDI context, skipping prconfig setting lookup
21-Jul-2022 10:31:38.548 INFO [main] com.pega.pegarules.internal.bootstrap.SettingReaderJNDI. Could not find prbootstrap in the local JNDI context, skipping prconfig setting lookup
21-Jul-2022 10:31:38.550 INFO [main] com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource. Bootstrap datatables schema: pegadata
21-Jul-2022 10:31:39.244 INFO [main] com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource. Archive version [0 ]
21-Jul-2022 10:31:39.245 INFO [main] com.pega.pegarules.internal.bootstrap.PRBootstrap. Engine schema defined in allclasses: null
21-Jul-2022 10:31:39.246 INFO [main] com.pega.pegarules.internal.bootstrap.PRBootstrap. Engine classes schema: pegarules
21-Jul-2022 10:31:39.246 INFO [main] com.pega.pegarules.internal.bootstrap.PRBootstrap. Assembled classes schema: pegarules
21-Jul-2022 10:31:39.246 INFO [main] com.pega.pegarules.internal.bootstrap.PRBootstrap. prbootstrap.properties merged with prbootstrap entries in Data-Admin-System-Settings
21-Jul-2022 10:31:39.926 INFO [main] com.pega.pegarules.internal.bootstrap.PRBootstrap. Using latest detected engine version:(EngineCodeSetVersion= 08-06-06). To specify a different version, use the setting com.pega.pegarules.bootstrap.codeset.version.Pega-EngineCode in prbootstrap.properties.
21-Jul-2022 10:31:39.929 INFO [main] com.pega.pegarules.internal.bootstrap.PRMiniLoader. Will load phase 2 bootstrap from Pega-EngineCode:08-06-06
21-Jul-2022 10:31:40.030 INFO [main] com.pega.pegarules.internal.bootstrap.phase2.PRBootstrapImpl. Using PRAppLoader implementation class: com.pega.pegarules.bootstrap.loader.PRAppLoader
21-Jul-2022 10:31:43.213 INFO [main] com.pega.pegarules.internal.bootstrap.phase2.PRBootstrapImpl. PegaRULES signed jar files will be extracted to: /opt/tomcat/work/Catalina/localhost/prweb/extractedFiles
21-Jul-2022 10:31:45.324 INFO [main] com.pega.pegarules.internal.bootstrap.phase2.PRBootstrapImpl. PegaRULES classes will be loaded from the database
21-Jul-2022 10:31:45.369 INFO [main] com.pega.pegarules.internal.util.PRProtectionDomainCache. PRProtectionDomainCache is using a WeakReference for pdcache HashMap values.
21-Jul-2022 10:31:45.625 INFO [main] com.pega.pegarules.internal.bootstrap.PRBootstrap.
============ PegaRULES Bootstrap Configuration ============
Date: Thu Jul 21 10:31:45 WIB 2022
Java Version: Red Hat, Inc. 1.8.0_332
Configuration: file:/opt/tomcat/webapps/prweb/WEB-INF/classes/prbootstrap.properties
Pega-EngineCode: 08-06-06
ASM Version: 1093239078
Database: PostgreSQL 11.16
Driver: PostgreSQL JDBC Driver 42.3.6
Active CodeSets: pega-enginecode:08-06-06 at (latest patch)
customer:06-01-01 at (latest patch)
=============== End Bootstrap Configuration ===============
[WebAppLifeCycleListener] Log4j Shutdownhook disabled
[WebAppLifeCycleListener] Setting pega.logdir to javax.servlet.context.tempdir
Current "user.dir" (default directory) is: /opt/tomcat/bin
Current pega.logdir is: /opt/tomcat/work/Catalina/localhost/prweb
Located PegaRULES logging configuration: file:/opt/tomcat/webapps/prweb/WEB-INF/classes/prlog4j2.xml
Unable to locate PegaRULES old logging configuration after trying:
<properties>
root-prlogging.xml
pega1-prlogging.xml
prlogging.xml
2022-07-21 10:31:47,183 [ main] [ ] [ ] [ ] (ervlet.WebAppLifeCycleListener) INFO - System Start Date: Thu Jul 21 10:31:47 WIB 2022
2022-07-21 10:31:47,218 [ main] [ ] [ ] [ ] (ervlet.WebAppLifeCycleListener) INFO - PegaRULES Web Tier 8.6.5
2022-07-21 10:31:47,218 [ main] [ ] [ ] [ ] (ervlet.WebAppLifeCycleListener) INFO - PRPC-8.6.5-749: 2022-06-21 03.15 EDT
2022-07-21 10:31:47,218 [ main] [ ] [ ] [ ] (ervlet.WebAppLifeCycleListener) INFO - prpc-platform.git (d1822cfe406048bd2edf040d715e5c24faa0be56)
2022-07-21 10:31:47,218 [ main] [ ] [ ] [ ] (ervlet.WebAppLifeCycleListener) INFO - Now starting the PegaRULES Web Tier...
2022-07-21 10:31:47,300 [ main] [ ] [ ] [ ] ( context.web.WebEnvironment) INFO - Web tier using local JNDI context
factory = org.apache.naming.java.javaURLContextFactory
url = <not specified>
path = java:
2022-07-21 10:31:47,300 [ main] [ ] [ ] [ ] ( priv.context.JNDIEnvironment) INFO - Web-tier default Engine bean name is EngineBMT
2022-07-21 10:31:48,120 [ main] [ ] [ ] [ ] (les.internal.ModulesBridgeImpl) INFO - Initializing engine modules.
2022-07-21 10:31:49,049 [ main] [ ] [ ] [ ] (nternal.NodeClassificationImpl) INFO - Node is started without applicableNodeTypes. Hence applicableNodeTypes will be the default list: [Search, WebUser, BIX, BackgroundProcessing, Custom1, Custom2, Custom3, Custom4, Custom5, DDS, ADM, Batch, RealTime, RTDG, Stream]
2022-07-21 10:31:49,050 [ main] [ ] [ ] [ ] (nternal.NodeClassificationImpl) INFO - Node Started with Universal type, Ignoring all other NodeTypes passed if any
2022-07-21 10:31:49,050 [ main] [ ] [ ] [ ] (nternal.NodeClassificationImpl) INFO - NodeTypes considered on current node = [Search, WebUser, BIX, BackgroundProcessing, Custom1, Custom2, Custom3, Custom4, Custom5, DDS, ADM, Batch, RealTime, RTDG, Stream] , for given -DNodeType = [ universal ]
Located PegaRULES configuration: file:/opt/tomcat/webapps/prweb/WEB-INF/classes/prconfig.xml
2022-07-21 10:31:49,169 [ main] [ ] [ ] [ ] (nal.DefaultConfigurationSource) INFO - prconfig.xml merged with prconfig entries in Data-Admin-System-Settings
2022-07-21 10:31:49,239 [ main] [ ] [ ] [ ] ( internal.guice.ClusterModule) INFO - Infinity is using Hazelcast Enterprise 3.12.10 for clustering. This version of Hazelcast is not supported anymore.
Please set the prconfig setting 'cluster/hazelcast/v4/enabled=true' to switch to Hazelcast Enterprise 4.1.1 . Refer Admin Guide for more details.
2022-07-21 10:31:49,245 [ main] [ ] [ ] [ ] ( DataGrid-Provider) INFO - Datagrid module is using undefined datagrid provider
2022-07-21 10:31:49,247 [ main] [ ] [ ] [ ] ( DataGrid-Provider) INFO - Datagrid module overridden to use hazelcast datagrid provider
2022-07-21 10:31:49,336 [ main] [ ] [ ] [ ] (nternal.MessagingConfiguration) INFO - Messaging provider is undefined
2022-07-21 10:31:59,005 [ main] [ ] [ ] [ ] (rnal.DefaultVirtualTableConfig) INFO - Using Hybrid Virtual Rules Table implementation
2022-07-21 10:31:59,005 [ main] [ ] [ ] [ ] (rnal.DefaultVirtualTableConfig) INFO - VTable dispatches rules for 9 Aspects: 'Validate, Collection, Decision, Action, Alias, Input, Model, ParamAction, When'.
2022-07-21 10:31:59,006 [ main] [ ] [ ] [ ] (rnal.DefaultVirtualTableConfig) INFO - ABA[AC] dispatches rules for 1 Aspect: 'Stream'.
2022-07-21 10:31:59,008 [ main] [ ] [ ] [ ] ( priv.context.JNDIEnvironment) INFO - Enterprise-tier default Engine bean name is EngineBMT
2022-07-21 10:31:59,008 [ main] [ ] [ ] [ ] (r.context.EtierEnvironmentImpl) INFO - Enterprise tier using local JNDI context
path = java:
2022-07-21 10:31:59,037 [ main] [ ] [ ] [ ] (ion.internal.PRGenProviderImpl) INFO - invokeDynamic instrumentation for inlining is enabled
2022-07-21 10:31:59,037 [ main] [ ] [ ] [ ] (ion.internal.PRGenProviderImpl) INFO - Assembly Version: 1093239078
Using sun.misc.Perf high-resolution timer for elapsed timings
2022-07-21 10:32:00,655 [ main] [ ] [ ] [ ] ( external.timers.CpuTimer) INFO - CPU timers set to TOTALSONLY. Use prconfig setting 'initialization/CpuTimerLevel' with one of [FULL, TOTALSONLY, NONE] to modify.
2022-07-21 10:32:00,658 [ main] [ ] [ ] [ ] (.timers.EnvironmentDiagnostics) INFO - Using Java 1.5 Thread.getAllStackTraces() for thread dumps
Using Java 5 Management beans for thread CPU timings.
Using Java 5 Management beans for process CPU timings: 31190000000
2022-07-21 10:32:01,054 [ main] [ ] [ ] [ ] (.access.PageDatabaseMapperImpl) INFO - DeflateStreams is turned ON.
2022-07-21 10:32:01,086 [ main] [ ] [ ] [ ] (pboard.StorageStreamCommonImpl) INFO - engineCodeVersion: 08-06-06
2022-07-21 10:32:02,069 [ main] [ ] [ ] [ ] (ecutor.StartupTaskExecutorImpl) INFO - Submitted tasks as part of startup task executor: [OVERRIDE_CONCLUSIONS, ACCESS_INFO_CONCLUSIONS, CLASS_MAP, FIELD_VALUE_CONCLUSIONS, PZ_PROPERTY_INFO_CONCLUSIONS, CLASS_INFO_CONCLUSIONS, RULE_FILE_BINARY_CONCLUSIONS, PY_PROPERTY_INFO_CONCLUSIONS, PX_PROPERTY_INFO_CONCLUSIONS]
2022-07-21 10:32:02,072 [StartUp-TaskExecutor] [ ] [ ] [ ] (ary.ClassMapDatabasePageReader) INFO - ClassMap using multi-tenant environment: false
2022-07-21 10:32:02,158 [ main] [ ] [ ] [ ] ( LogHelper) INFO - alert Enabled true
2022-07-21 10:32:02,158 [ main] [ ] [ ] [ ] ( LogHelper) INFO - Setting alerts/granular/maxAlertCountInTimePeriod :
2022-07-21 10:32:02,158 [ main] [ ] [ ] [ ] ( LogHelper) WARN - No setting for alerts/granular/maxAlertCountInTimePeriod
2022-07-21 10:32:02,165 [StartUp-TaskExecutor] [ ] [ ] [ ] (ary.ClassMapDatabasePageReader) INFO - Reading the class group definitions
2022-07-21 10:32:02,227 [ main] [ ] [ ] [ ] ( internal.archive.ParUtilsImpl) INFO - Setting archive staging directory: /usr/pegatemp/RuleMgmt
2022-07-21 10:32:02,234 [StartUp-TaskExecutor] [ ] [ ] [ ] (ary.ClassMapDatabasePageReader) INFO - Read 29 class group definitions
2022-07-21 10:32:02,234 [StartUp-TaskExecutor] [ ] [ ] [ ] (ary.ClassMapDatabasePageReader) INFO - Reading the class definitions
2022-07-21 10:32:02,237 [ main] [ ] [ ] [ ] ( etier.impl.EngineStartup) INFO - JVM Information:
2022-07-21 10:32:02,237 [ main] [ ] [ ] [ ] ( etier.impl.EngineStartup) INFO - Vendor: Red Hat, Inc., JVM version: 1.8.0_332
2022-07-21 10:32:02,237 [ main] [ ] [ ] [ ] ( etier.impl.EngineStartup) INFO - VM Name: OpenJDK 64-Bit Server VM(build 1.8.0_332-b09)
2022-07-21 10:32:02,237 [ main] [ ] [ ] [ ] ( etier.impl.EngineStartup) INFO - Host OS Information:
2022-07-21 10:32:02,237 [ main] [ ] [ ] [ ] ( etier.impl.EngineStartup) INFO - OS: Linux, version: 3.10.0-1160.71.1.el7.x86_64
2022-07-21 10:32:02,237 [ main] [ ] [ ] [ ] ( etier.impl.EngineStartup) INFO - Architecture: amd64
2022-07-21 10:32:02,237 [ main] [ ] [ ] [ ] ( etier.impl.EngineStartup) INFO - PegaRULES Enterprise Tier 8.6.5
2022-07-21 10:32:02,237 [ main] [ ] [ ] [ ] ( etier.impl.EngineStartup) INFO - PRPC-8.6.5-749: 2022-06-21 03.15 EDT
2022-07-21 10:32:02,237 [ main] [ ] [ ] [ ] ( etier.impl.EngineStartup) INFO - Deployed in web tier only
2022-07-21 10:32:02,237 [ main] [ ] [ ] [ ] ( etier.impl.EngineStartup) INFO - Servlet container: Tomcat
2022-07-21 10:32:02,238 [ main] [ ] [ ] [ ] ( etier.impl.EngineStartup) INFO - Web server: Apache Tomcat/9.0.64
2022-07-21 10:32:02,238 [ main] [ ] [ ] [ ] ( etier.impl.EngineStartup) INFO - Web server environment: Tomcat
2022-07-21 10:32:02,238 [ main] [ ] [ ] [ ] ( etier.impl.EngineStartup) INFO - Web-tier default Engine bean name: EngineBMT
2022-07-21 10:32:02,238 [ main] [ ] [ ] [ ] ( etier.impl.EngineStartup) INFO - Web to Enterprise tier delegate type: pojo
2022-07-21 10:32:02,238 [ main] [ ] [ ] [ ] ( etier.impl.EngineStartup) INFO - Now starting the PegaRULES Engine...
2022-07-21 10:32:02,310 [ main] [ ] [ ] [ ] ( internal.mgmt.PRNodeImpl) WARN - tier name was not provided. setting it to default
2022-07-21 10:32:02,393 [ main] [ ] [ ] [ ] ( internal.mgmt.PRNodeImpl) INFO - Using codeset version and timestamp map: {pega-enginecode=08-06-06@2022-07-20 11:28:00.0, customer=06-01-01@1970-01-01 07:00:00.0}
2022-07-21 10:32:02,473 [StartUp-TaskExecutor] [ ] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Bytes input per interaction warning threshold: 50M
2022-07-21 10:32:03,375 [ pega1] [ ] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Generated source : file://runtime:/PRGenJava/
2022-07-21 10:32:03,375 [ pega1] [ ] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Generated classes: file://runtime:/PRGenClasses/
2022-07-21 10:32:03,392 [ pega1] [ ] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Web-tier real root path: /opt/tomcat/webapps/prweb
2022-07-21 10:32:03,392 [ pega1] [ ] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Web-tier temporary path: /opt/tomcat/work/Catalina/localhost/prweb
2022-07-21 10:32:03,392 [ pega1] [ ] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - PegaRULES real root path: /opt/tomcat/webapps/prweb
2022-07-21 10:32:03,392 [ pega1] [ ] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - PegaRULES effective root path: file://default:/
2022-07-21 10:32:03,392 [ pega1] [ ] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - PegaRULES effective temp path: /usr/pegatemp
2022-07-21 10:32:03,392 [ pega1] [ ] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Using genSourcePath: file://runtime:/PRGenJava/
2022-07-21 10:32:03,392 [ pega1] [ ] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Using genClassPath (database): pegajdbc://474488818:1/
2022-07-21 10:32:03,392 [ pega1] [ ] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Using genClassPath (files): file://runtime:/PRGenClasses/
2022-07-21 10:32:03,392 [ pega1] [ ] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Using external classes in: <not using external classes>
2022-07-21 10:32:03,392 [ pega1] [ ] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Using external jars in: <not using external jars>
2022-07-21 10:32:03,467 [ pega1] [ ] [ ] [ ] (nal.compiler.PRCompilerEclipse) INFO - Compile-time java library classpath:
/usr/lib/jvm/java-1.8.0-openjdk- Proprietary information hidden.b09-1.el7_9.x86_64/jre/lib/resources.jar;
/usr/lib/jvm/java-1.8.0-openjdk- Proprietary information hidden.b09-1.el7_9.x86_64/jre/lib/rt.jar;
/usr/lib/jvm/java-1.8.0-openjdk- Proprietary information hidden.b09-1.el7_9.x86_64/jre/lib/jsse.jar;
/usr/lib/jvm/java-1.8.0-openjdk- Proprietary information hidden.b09-1.el7_9.x86_64/jre/lib/jce.jar;
/usr/lib/jvm/java-1.8.0-openjdk- Proprietary information hidden.b09-1.el7_9.x86_64/jre/lib/charsets.jar;
/usr/lib/jvm/java-1.8.0-openjdk- Proprietary information hidden.b09-1.el7_9.x86_64/jre/lib/jfr.jar;
/usr/lib/jvm/java-1.8.0-openjdk- Proprietary information hidden.b09-1.el7_9.x86_64/jre/lib/ext/cldrdata.jar;
/usr/lib/jvm/java-1.8.0-openjdk- Proprietary information hidden.b09-1.el7_9.x86_64/jre/lib/ext/dnsns.jar;
/usr/lib/jvm/java-1.8.0-openjdk- Proprietary information hidden.b09-1.el7_9.x86_64/jre/lib/ext/jaccess.jar;
/usr/lib/jvm/java-1.8.0-openjdk- Proprietary information hidden.b09-1.el7_9.x86_64/jre/lib/ext/localedata.jar;
/usr/lib/jvm/java-1.8.0-openjdk- Proprietary information hidden.b09-1.el7_9.x86_64/jre/lib/ext/nashorn.jar;
/usr/lib/jvm/java-1.8.0-openjdk- Proprietary information hidden.b09-1.el7_9.x86_64/jre/lib/ext/sunec.jar;
/usr/lib/jvm/java-1.8.0-openjdk- Proprietary information hidden.b09-1.el7_9.x86_64/jre/lib/ext/sunjce_provider.jar;
/usr/lib/jvm/java-1.8.0-openjdk- Proprietary information hidden.b09-1.el7_9.x86_64/jre/lib/ext/sunpkcs11.jar;
/usr/lib/jvm/java-1.8.0-openjdk- Proprietary information hidden.b09-1.el7_9.x86_64/jre/lib/ext/zipfs.jar
2022-07-21 10:32:05,099 [StartUp-TaskExecutor] [ ] [ ] [ ] (ary.ClassMapDatabasePageReader) INFO - Read 6459 class definitions
2022-07-21 10:32:06,153 [StartUp-TaskExecutor] [ ] [ ] [ ] (ternal.dictionary.ClassMapImpl) INFO - ClassMapData is preloaded
2022-07-21 10:32:06,517 [StartUp-TaskExecutor] [ ] [ ] [ ] (ternal.dictionary.ClassMapImpl) INFO - ClassMap initialization completed in 4452 ms
2022-07-21 10:32:06,520 [StartUp-TaskExecutor] [ ] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Database product: PostgreSQL
2022-07-21 10:32:06,520 [StartUp-TaskExecutor] [ ] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Database version: 11.16
2022-07-21 10:32:06,520 [StartUp-TaskExecutor] [ ] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Driver: PostgreSQL JDBC Driver
2022-07-21 10:32:06,520 [StartUp-TaskExecutor] [ ] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Driver version: 42.3.6
2022-07-21 10:32:06,520 [StartUp-TaskExecutor] [ ] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Version of JDBC supported by driver: 4.2
2022-07-21 10:32:06,707 [StartUp-TaskExecutor] [ ] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Using optimized batch ID generation. IDs will be generated in batches and may not be strictly sequential
2022-07-21 10:32:06,794 [StartUp-TaskExecutor] [ ] [ ] [ ] ( internal.access.Lister) INFO - Fetch size for certain Postgres RDB queries is enabled
2022-07-21 10:32:07,390 [StartUp-TaskExecutor] [ ] [ ] [ ] (rnal.access.CacheContainerImpl) INFO - Using the Dynamic Cache Probation Policy - cache after 2 accesses AND with a blob increment of 102400.
2022-07-21 10:32:07,410 [ pega1] [ ] [ ] [ ] (rnal.access.CacheContainerImpl) INFO - Using the Dynamic Cache Probation Policy - cache after 2 accesses AND with a blob increment of 102400.
Pega Rules log:
2022-07-21 03:32:03,553 GMT*8*PEGA0005*1275*500*NA*NA*NA*NA*NA*NA*NA*NA*?*-1**0*NA*NA*com.pega.pegarules.data.internal.store.DataStorePreparedStatement*NA*NA*NA*NA*NA*false*NA**NA*NA*NA*NA*NA*NA*NA*NA*Database query took more than the threshold of 500 ms: 1,275 ms SQL: select pzPVStream from pegarules.pr4_base where pxObjClass = ?*
2022-07-21 03:32:08,345 GMT*8*PEGA0005*754*500*NA*NA*NA*NA*NA*NA*NA*NA*?*-1**1*NA*NA*com.pega.pegarules.data.internal.store.DataStorePreparedStatement*NA*NA*NA*NA*NA*false*NA**NA*NA*NA*NA*NA*NA*NA*NA*Database operation took more than the threshold of 500 ms: 754 ms SQL: SELECT pzUCShortInsId AS "pzUCShortInsId", pyFieldName AS "pyFieldName", pyFieldValue AS "pyFieldValue", pyLocalizedValue AS "pyLocalizedValue", pyRuleSet AS "pyRuleSet", pyRuleSetVersion AS "pyRuleSetVersion", pyClassName AS "pyClassName", pyRuleAvailable AS "pyRuleAvailable", pzInsKey AS "pzInsKey", pxUpdateDateTime AS "pxUpdateDateTime" FROM pegarules.pr4_fieldvalue WHERE pyRuleAvailable != 'No' ORDER BY pzUCShortInsId*
2022-07-21 03:32:08,603 GMT*8*PEGA0005*1014*500*NA*NA*NA*NA*NA*NA*NA*NA*?*-1**2*NA*NA*com.pega.pegarules.data.internal.store.DataStorePreparedStatement*NA*NA*NA*NA*NA*false*NA**NA*NA*NA*NA*NA*NA*NA*NA*Database operation took more than the threshold of 500 ms: 1,014 ms SQL: select distinct pxRuleFamilyName as "pxRuleFamilyName" from pegarules.pr_index_reference where pxInsIndexedClass = 'Rule-File-Text' and pxRuleObjClass = 'Rule-File-Binary' and pxReferencingRulesetName like 'Pega-%'*
