Install Bootstrap in Pega 7.2.1 (unsuccessful but no error message )
We need to use some components from Bootstrap. For that we need to reference external files. Adding the below in our HTML rule works fine:
<link rel="stylesheet" href="https://maxcdn.bootstrapcdn.com/bootstrap/3.3.7/css/bootstrap.min.css">
<script src="https://maxcdn.bootstrapcdn.com/bootstrap/3.3.7/js/bootstrap.min.js"></script>
<script src="https://ajax.googleapis.com/ajax/libs/jquery/3.1.1/jquery.min.js"></script>
However, we would like to store/install them in Pega and reference them as we reference local js/css file.
I have currently downloaded bootstrap 3.3.7 and copy pasted its content in a Text File rule.
(More specifically I copy pasted the content of those files: bootstrap.min.js and bootstrap.min.css. They didnt work, so I also tried referencing bootstrap.js and bootstrap.css)
I then referenced those Text File from the HTML rule.
I am not getting any error but it doesnt seem that Pega is referencing Bootstrap
Any hint or help will be greatly appreciated:)
Thank you in advance for your help :)
Mariane
It was solved by re-ordering the scripts, it has to be in the following order to work:
<link href='webwb/bootstrap.min.css' rel="stylesheet">
<script src='webwb/JQuery.js' rel="stylesheet"></script>
<script src='webwb/bootstrap.min.js' rel="stylesheet"></script>
Thank you :)
Mariane
