I imported data records from csv into the data type (Pega 7.2) with leading zeros. The property is defined as text, but pega report doesn't show the leading zeros.
I imported data records from csv into the data type (Pega 7.2) with leading zeros. The property is defined as text, but pega doesn't show the leading zeros. Is there any solution for that problem?
The values of the property look e.g. like this 02345. The import did function, because when I look on the instances of the class, that was created I can see, that the values are right.
For any help thanks in advance.
