HCL Technologies
Last activity: 28 Nov 2016 8:25 EST
I am getting error message while install Pega like "Unable to connect to database"
PEG
Did "Test Database Connection" step succeeded?
HCL Technologies
How to check the Database Connection
Hi Sarath,
Page where you configure Database details, you would see Test connection button to test Database connection.
Please do test connectivity to see you have proper DB connection.
HCL Technologies
Please be informed that i have not confgiured any database, i am having the issue during my initial stages
After Download 114898_PE719 package, while installing i am getting error, here i am following the 719PersonalEditionInstallation.pdf document
I hope this clarify to you for resolving the issue
This is personal edition, so its bundled with Tomcat and PostgreSQL. No special DB configuration should be needed. Did you follow this document:
https://docs-previous.pega.com/personal-edition-installation-guide-719
Are you running install.bat script? Can you share the install logs?
HCL Technologies
Thanks for your support
I am successfully install the Pega, and now i am in login screen, its asking for username and password
can you let me know what is the username and password i have to provide
Thanks & Regards
Sarathbabu.S
HCL Technologies
Can you please clarify my question
Citicorp Services India Private Limited
Hi Saratth,
The login details is mentioned in the document shared by Aditya Sirohi . The login detail is present in Page 10 at setp 14
14. Log in to the Pega 7 Platform instance as [email protected] with a password of install to verify that you can access the Designer Studio.
Please let me know if this helps,
Gowrishankar.
HCL Technologies
Thanks for the information
Yes, The login details is:
User name: [email protected]
Password: install
You can mark the discussion as answered if you issue has been resolved.
Infosys
what is default ID/ password for tomcat? In case we need to login to server in local machine?
If it isn't admin/admin as the link mentions check your tomcat conf folder for your tomcat-users.xml file.
The user with the admin-gui role is likely the one of interest.
Wipro Ltd
I beleive both 'admin-gui' and manager-gui show be added as below.
<user username="admin" password="rules" roles="admin-gui,manager-gui"/>
