How to show progress bar while uploading attachment file to Server?
I am using a OOTB attachment control for uploading files to server.
When you click the attachment button, it pops up a window let you drag&drop or select files to upload.
There is a problem that after user drag&drop or select a file , the system starts to upload process immediately,
but the attachment pop-up window remain unchanged until the uploading file process completed.
so user will confused about if the process has been started or yet, because there is no message like [ file is uploading...] , UI is just remain the same.
I am trying to show a progress bar after user selected a file to upload, If anyone who has experience on this, could you give some advice how to develop it?
( I found there is an OOTB control , pzProgressBar, maybe I can use this.)
