Deloitte
Last activity: 20 Sep 2017 2:50 EDT
How to implement a progress bar
Hi, we are implementing a survey in Pega for my client. They asked if I can implement a progress bar based on the amount of questions answered (Questions Completed/Total Questions *100). Can anyone help me with this? I can't seem to find a guide.
You can use pzProgressBar control to display a progress bar on the UI screen with the progress/status completed
Thank You.
Deloitte
Hi, Thanks for your answer.
I can't seem to find a pzProgressBar when I search for it..
Which PRPC version are you using?
Anyways I am attaching the control code snippet. In case you didn't find, create a new control using the attached code.
Deloitte
Thank you. I will try this. Im using Pega 7.3. I found pzProgressBar, by adding "old:". I will see how far I can get! Thanks again
vasavi college of engineering
Hey, Did you get the implementation?, If so, Please share your usecase and the solution, Even I need a help on this, Thanks :)
Deloitte
Hi, not yet. We will be working on this, hopefully, this week. Whenever I have the solutions I will share it with you! Best, Ozin
Deloitte
Can anyone give a detailed description on how to make it work? Only adding the pzProgressBar control won't show any progress, how do I set up the parameters?
J.P. Morgan Services India PVT Ltd
can you please go through this once:
