Pega UI not displaying asterisk(*) in error message
How to show * in an error message on the screen.
Hi @vin8867,
It will definitely show the * special character on the UI. Even if you gave the * directly in the error message box.
and @Hitesh Jain gave suggestion "*" , This is also fine; but give * double quotes will not allow.
and If you observe the below screenshot, there is a drawback if you give it like this: *, it shows only in one place, * and another place it will show the as it is like *
Where you are calling this Validate Rule and How are you Checking in the Tracer and UI
I hope this will help you.
Ashok
Hi @vin8867,
Ashok
