Error message not displaying in UI
I am using pxAddmessage in Data transform to set error message in screen. I am getting an error message in Clipboard but the error is not showing in screen. I used the same pxaddmessage in other DT's too its working fine for me. But in this particular DT it is not displaying.
My when condition is simple one.
Property1 is >= prop2 then set the error message.
Both the properties are pagelist. It is configured in Table. I called the DT in Action set of those properties in Table.
Can some one suggest me to solve this??
Are you trying to do this on modal dialog? If yes, you need to include one section called "DisplayErrors" to display the error.
