Capgemini
MX
Last activity: 28 Jul 2022 14:00 EDT
How to set properties without being inside a flow
I have a section that is not part of a flow, which has several fields, these fields keep the value that I write to it even when I reload or relaunch the portal, I would like these text input (properties) to be set to an empty value every time I launch the portal or reload the browser page. I tried to call an activity from the Defer loading content->Specify a preloading activity option, in the dynamic layout options where the text inputs are, but with this I only got the activity to run every time I write something in a field, so the activity deletes anything as soon as I write it, when what I need is for the activity to run only ONCE.
Is there any other way to set the properties only once to an empty value when launching or reloading the portal, or am I calling the activity from the wrong place?
