Morgan Stanley
Last activity: 4 Sep 2018 8:23 EDT
How to save a UI form data created inside an external portal?
Hello everyone. I am unable to save the data entered by an user during runtime. My requirement is to create a new portal which will contain a form with some fields for the end user to fill. I have configured a submit button on that form to save the data into clipboard(pyWorkPage) and create the workobject .
But when I click on submit button the work object created is holding null values for all the properties defined in UI. Please anyone help me with the fix to save the property values to my pyworkpage.
Action set defined onn the button:-
Event -On Click Action-1.Save 2.Create Work
You can define parameters to the flow rule and pass the clipboard values to the flow through the parameters.
Set the parameters values on pyWorkPage in pyDefault.
Here the issue is the thread context gets changed when you create a workobject you have to pass the values to the newly generated thread for new work object
