How do I disable display of Knowledge Management in the Interaction Portal?
Hi all,
I am trying, but failing, to remove the Knowledge Management bar from our interaction portal.
As far as I can understand, I should be able to go into App Studio > General > Knowledge management and untick the 'Enable display of knowledge articles' checkbox.
However, as pictured in the attached screenshot, all 'Knowledge management' settings are greyed out, and I am unable to edit them. I have searched for an answer with no luck, I have unlocked a PegaKM ruleset version to see if that would allow me to make changes, but to no avail.
Can someone please help me to remove the Knowledge management bar?!
Thank you in advance,
Carly
@Carly the global search bar is not part of knowledge management. You cannot remove the global search without customization.
