AtoS Global IT SOlutions
Last activity: 27 Nov 2017 3:35 EST
How to Install Pega 7.3.1 Personal Edition?
I am trying to install Pega 7.3.1 on my personal computer but the database connection is not getting successful.
System Config:
1. Windows 10
2. RAM - 4GB
3. Oracle 11g R2
4. Error while connection - Exception testing connection:
IO Error: The Network Adapter could not establis the connection
5. JDBC Driver Class Name - oracle.jdbc.OracleDriver
6. JDBC Driver JAR file - ojdbc7.jar
7. Database JDBC URL - jdbc:oracle:thin:@//localhost:1521/dbName
8. Rules Schema Name
9. Data Scheme Name
Please help to setup.
Hi Sinhal,
I would like to know whether you are installing the personal edition or standard edition of Pega 7.3.1?
If you are trying to install personal edition then the installation process is different as explained over here.
If you are trying to install the standard edition with the Single/Split schema concept you can look for the reference document over here. You can refer the specific document based on your Database and Application Server.
Hope this might help you to understand the installation process.
Regards
Mahesh
