Virtusa Corp.
Last activity: 24 Aug 2017 4:58 EDT
How to Import BPMN flows
Is there any way to import the flows of other BPMN notations like BPEL, Visio formats into Pega? Rule From File Wizard but dint yield any successful results.
what version of pega are you using? You mentioned that it was not successful, what error are you getting?
Virtusa Corp.
Hi Kevin,
I tried in Pega 7.1.9 PE and 7.1.6. After the import is successful, flow got created but with a blank screen i.e with out any flow shapes.
Yes, the Rule From File wizard and its import options haven't changed. Thomas Kaufmann has done the most work recently in this area.
See the answer from Ken. I think you should go ahead with a SR with details (including the files used).
Bank of America
Hi Sri charan,
Did you find any way to do this ? even I tried the same and it created flow rules without any shapes in it.
I strongly encourage you to open an SR.
Hi Sri Charan,
Please let us know here if you have opened an SR so that we may track it through this post!
Lochan
First Tech Federal Credit Union
Hi Sri,
Request you to share a share sample BPEL/BPMN file.
Rushikesh
Infosys
How do we import flows into PEGA? do we have wizard for this?
