Virtusa
Last activity: 22 Sep 2015 3:18 EDT
How to get the Connect SDK?
We are building solution by using the Pega mobile AMP/ConnectSDK. Is there any download link available to download the libs for iOS and Android
Karthik S
I am sure you have read this article: https://collaborate.pega.com/discussion/connect-sdk-and-consuming-backend-web-services. Contact Pega GCS to get the PegaMobile media.
to be exact: 114724_MMSDK717 (Pega Mobile Mashup)
Virtusa
I believe Mashup and Connect SDK are different. isn't it?
Mashup is like loading the webapps in native container, whereas connectsdk is like only the service call uses PEGA 7 and UI will be in either iOS or Android code.
You might be right. I could not find the apis under the Mashup SDK download… However, I cannot find ConnectSDK media myself in the software distribution application, hopefully someone who knows this will reply.
Lukasz Zajac can you please answer the question regarding how to get the ConnectSDK library file connectsdk.pegaapi- Proprietary information hidden.aar?
PL
Hi Kevin
Attached is Connect SDK Proprietary information hidden with libraries for both iOS and Android.
Apologies for the confusion - it has not been added to 114724_MMSDK717.
The library is going to be released soon in a single package called "Pega Mobile SDK", featuring both Connect SDK and new Mashup SDK.
Regards
Lukasz Zajac
Virtusa
Thanks Kevin and Lukasz..
Regards
Karthik S
Karthik,
Can you share the use case that you are building out? You are one of the first consumers of this so we want to be aware of how this is being used.
Stephanie
CTS
I found this discussion very helpful as we were also looking for the Connect SDK libraries.
We are trying to implement the following use case:
UI on native iOS
Talks to Pega middleware platform using Connect SDKs.
From the Pega middleware platform, we talk to customer backend web services. (We are looking for more information around this. Can anyone help?).
Kind Regards,
Muddassar Alam
