SSL - Connect SDK
One of our clients is trying to use Connect SDK to retrieve information from Pega application. They are able to do it from IOS but they get below error from Android -
- javax.net.ssl.SSLHandshakeException:
- java.security.cert.CertPathValidatorException: Trust anchor for certification path not found.
at
- org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.startHandshake
(OpenSSLSocketImpl.java:374)
at libcore.net.http.HttpConnection.setupSecureSocket
(HttpConnection.java:209)
at libcore.net.http.HttpsURLConnectionImpl
$HttpsEngine.makeSslConnection(HttpsURLConnectionImpl.java:478)
at libcore.net.http.HttpsURLConnectionImpl$HttpsEngine.connect
(HttpsURLConnectionImpl.java:433)
at libcore.net.http.HttpEngine.sendSocketRequest
(HttpEngine.java:290)
at libcore.net.http.HttpEngine.sendRequest(HttpEngine.java:240)
at libcore.net.http.HttpURLConnectionImpl.getResponse
(HttpURLConnectionImpl.java:282)
at libcore.net.http.HttpURLConnectionImpl.getInputStream
(HttpURLConnectionImpl.java:177)
at libcore.net.http.HttpsURLConnectionImpl.getInputStream
(HttpsURLConnectionImpl.java:271)
at
This error has been documented in the Android Developer site ( https://developer.android.com/training/articles/security-ssl.html#UnknownCa ) with some common causes of this problem. They would like to follow the solution mentioned in the link under "Unknown CA" option but they are not finding the way to attach custom SSLSocketFactory with the ConnectSDK library?
***Edited by Moderator Marissa to update SR Details & add FDBK ID***
