Last activity: 29 Jun 2022 8:58 EDT
React SDK update – SDK-R.86.3 now available!
A new release of the React SDK is now available – SDK-R.86.3
Marketplace download: https://community.pega.com/marketplace/components/react-sdk
Github code repository: https://github.com/pegasystems/react-sdk/release/8.6
Updates include:
This is the first release of the React SDK for Infinity 8.6.4. (A separate release is available for Infinity 8.7.1)
Use the corresponding ConstellationJS files found in the SDK-R.86.3 download from Pega Marketplace: https://community.pega.com/marketplace/components/react-sdk
The React SDK does not include every component that a Constellation application supports. At this time, we provide the most commonly used components to get you started with your application.
Background:
The React SDK includes a bridge and components that connect the Constellation JavaScript (ConstellationJS) Engine to a React-based design system that is different than the standard React Cosmos design system. The SDK provides a front-end developer friendly NodeJS environment for building an application’s UI using a different design system than Cosmos. The alternative design system used in this React SDK is Material UI.
