Infosys Ltd
Last activity: 9 Aug 2019 2:56 EDT
How to Enable/Disable Queue Processor and Job scheduler in higher environments with data instances
Hi ,
Can any one please clarify below questions.
1) About Data Instance
In pega v7 , we can see agent schedule data instance to enable/disable agents, modify time interval, and change pattern in higher environments without modifying rule instance.
So, in the same way, How can we monitor/control the Queue processor and Job Scheduler in pega v8? I mean, i did not notice any data instance to control these rules.
2) Queuing Items into DB.
In pega v7, if we want to have queing the records. we would do the following things:
-> Create class under System-Queue-XXXX
-> we will map these class to some DB table.
Once agent wakes up, standard agent will look into these table for any queing items from DB. if so, it will proceed with processing.
In the same way, how can we implement queuing mechanism in the Queue processor?
because, i checked in the PDN article saying that, Queue processor doesn't need to queue the items into DB.
Thanks in advance,
Ravi
