How dose multi node(cluster) system works
Do we have to deploy same application on all nodes?
How the nodes manage load management?
Yes you need to deploy same application on multiple nodes, to distribute the load.
In addition to that you need to deploy load-balancer.
Please refer the below links for addtional info :
https://community.pega.com/sites/default/files/help_v722/procomhelpmain.htm availability/architecture/eng-high-availability-load-balancers-con.htm
https://docs-previous.pega.com/performance/load-balancing-multi-node-cluster
