Last activity: 17 Feb 2019 13:23 EST
How to Display the Tabs dynamically, meaning each document should open in a seperate Tab on UI in Pega 7.3
I used to achieve this functionality using Tab group and a dynamic container in pega 7.1.x versions. But Tab group is deprecated in 7.3 . Can anyone tell me if there is any other alternative to Tab group in pega 7.3 to display each document in a seperate Tab dynamically.
Hi Vamsi,
You can use the Layout group with category as "Tab" to implement the Tab layout.
Evita.
Tristan Young John Pritchard-Williams Amit Gujral Tim Lai
ANZ Banking Group Ltd
We can add a Tab layout from Layout group but..the question how to add dynamic container to Tabbed Layout Group.I
I am even facing the same issue.Anyone could you suggest the solution.
anusha talasu
Hi Anusha,
The Tab group layout already contains a container within it.
Additionally if you need to add another container, you can add a Dynamic layout and place the Dynamic container in it.
Evita.
Coforge india pvt ltd
Please use below steps to achieve the requirement.
TATA CONSULTANCY SERVICES
Hi Vamsi Kumar, I dont see the steps in the post. Can you please provide the detailed steps on how to achieve tab view for worklist/cases in portal
Telstra
Are we supposed to use 'Legacy'?
Telstra
Upon doing my research, we have to use 'Tab group' with a dynamic container. I guess there is no other option. Even Pega Dev harness has the same style. Have a look at section pzStudioContainerTabs of Data-Portal class.
I think below approach may work:
Inside a tab group or layout group you can add a section include and in this section you can add a dynamic container.
