NatWest Group
Last activity: 8 Mar 2019 5:11 EST
How to create subcase on click of button in parent case and also open it
Have a requirement where on click of button in parent case , a subcase should get created and it should also open up.
Citicorp Services India Private Limited
Could you configure Run Activity 'pxAddChildWork' in the button action and lets know if this works for you.
Gowrishankar.
NatWest Group
Activity 'pxAddChildWork' only creates the subcase but here I also want to open the subcase after creation.
NatWest Group
Narasimha vulisetti
American Express Services Europe Ltd
We have same requirement like this. Is there any way we can open and show the sub case to the user when it is from parent case?
Appreciate your help!
Tata Consultancy Services
Hi Veera,
You can use OpenWorkItem action by passing child case Id.
Merkle
Please check the below steps to create a service case from a service case, hope that will help to resolve your query:
- Use 'Call createWorkPage' to create WorkPage, note: step page would be some temp page(not pyWorkPage)
- Then set required properties in that WorkPage
- Then 'Call AddWork' to create the work object.
- Finality use the assignment key from the WorkPage to open the service case
Gopesh
Bhargav Shastrula Gayathri Gurumoorthy Sachin Gupta Srikanth Yangali
Merkle
Hi Sarabdeep,
Have you try that approach? Have you solved your problem?
Gopesh
Coforge
In the case type rule of the parent, you can check the 'Manual Instantiation' option for the child case type. This will add an item in the Actions menu for the user to add work and create the child case. When we click the case item here it will launch sub case. You can adjust your code accordingly by seeing the ootb add work menu item!!
Srinivas S
Cognizant
ES
I am trying this approach. I have a Case Type A, and a Case Type B. Case B is child of Case A. I set Manual Instantiation for Case B. Now, I have a Section on Case A, where I want to create (and open) a child Case B on click of a button. I used the Action "Create Work", and set Case B Class. This creates and opens a Case B, but it is not child of Case A! There is no pyWorkCover or ParentID, no data propagation...
How can I make it so that, when I click on the button, Case B will be created as a child of Case A?
NatWest Group
Using a script on click of button helped serve the purpose.
Script - "pega.ui.HarnessActions.addFlowFromActionsMenu"
It takes 2 parameters - flowType & flowClass
flowType - Configure a flow in parent case class & use Create Case smart shape to create child cases.
flowClass - class of parent case where flow is created.
Rafael Cuevas Mijangos
