How to create PDF to the case by using a buttom
Hello, our project has encountered some problems. Customers need to control the generation of PDF of case through buttons. Is there any OOTB method to try?
Use the OOTB pxCreatePDF activity on click on the button and pass the section for which you want to create the pdf, this will create and attach to add to the work object, if only to generate pdf use: HTMLToPDF.
