IP Australia
Last activity: 7 Aug 2023 10:35 EDT
How to configure stream node and kafka instance in 8.4
We have upgrade our pega application from 7.3.1 to 8.4, in upgrade guide it is mentioned that we need to open ports 9092 and 7003 to support stream node.
Do we have to explicitly setup any kafka cluster to connect to stream node of pega? or Pega internally is going to take care of it?
To open and configure the ports, what should be the source and destination for these ports?
If you use embedded stream service (which is the default for 8.4.x), Pega should take care of this. For Pega 8.4.x, you can also configure external stream service, see this link for details: https://community.pega.com/knowledgebase/articles/decision-management-overview/externally-managed-stream-service.
