Stream Node ?
We are planning for a base pega platform 8.8, Is having Stream Node mandatory I don't for see any requirements related to stream service or huge amounts of data processing.
Will plan to opt for Job Schedulers instead of Queue Processors in case of any back ground processing needed. Not sure how the OOTB Queue Processors will get impacted.
Is the below Setup ok ?
4 - WebUser
2- Batch
1 - Search
Does it change in case of containerizing with K8 ?
Can you please point me documentation about Stream Node.
