Stream Node stability in client managed cloud
We are using PEGA 8.8.1 on Client managed cloud and using auto heal ec2 instance for stream node (Stream and search both on same) and attached EBS volume to the EC2 instance.
Below are few issues that we are facing:
1. The stream node leave the cluster intermittently and we would need to rebuild the cloud ec2 instance for it to join the cluster
2. Whenever there is a need of new build i.e building a new cluster of nodes and old nodes are still there (including all nodes user, backgroound and stream node), the stream node has issue joining cluster. And as a workaround we kill all available nodes on that environment and clear enteries from pr_sys_statusnodes table and then build entire cluster again.
does anyone has encountered issues with Stream node joining cluster ? And if yes what did you do to resolve this issue permanently ?
Why only stream node has issue joining cluster ?
Does a failed stream node which did not join cluster can bring down other nodes?
