Help configuring Kafka Instance
I am trying to create a new Kafka instance with username and password authentication. I have the JVM argument Djava.security.auth.login.config pointing to my jaas config file. When I test connectivity, I get the message:
Connection Failed Error connecting to Kafka. Timeout expired while fetching topic metadata
There is nothing in the PegaRULES or ALERT logs to indicate what the issue is.
On which classes can DEBUG be enabled to get a better idea what is failing?
