Disable Kafka and DSM
Our 8.4 app logs keep on filling with messages like below.
Is Kafka, DSM necessary. We are not using these features...so how to disable them. So far I have decommissioned the node from Decision: Services > DDS, ADM, RTDB and Stream tabs.
prconfig/initservices/dnode/default is also false.
Anything else need to be done?
2020-04-24 22:10:15,591 [tionTask-Executor:42] [ STANDARD] [ ] [ ] (icepulse.RunInitializationTask) ERROR - Failed to prepare partitions for run [Aggregates_pxInteractionsStream]
java.lang.RuntimeException: java.util.concurrent.ExecutionException: com.pega.fnx.stream.spi.StreamServiceException: Invalid configuration. Undefined stream provider end point.
at com.google.common.base.Throwables.propagate(Throwables.java:160) ~[guava-19.0.jar:?]
at com.pega.dsm.dnode.impl.stream.DataObservableImpl.await(DataObservableImpl.java:142) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.stream.DataObservableImpl.await(DataObservableImpl.java:106) ~[d-node.jar:?]
at com.pega.dsm.dnode.api.dataflow.DataFlow.getDataPartitions(DataFlow.java:801) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.dataflow.service.servicepulse.PartitionCreator.createFor(PartitionCreator.java:80) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.dataflow.service.servicepulse.PartitionCreator.access$000(PartitionCreator.java:45) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.dataflow.service.servicepulse.PartitionCreator$1.run(PartitionCreator.java:62) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.dataflow.service.servicepulse.PartitionCreator$1.run(PartitionCreator.java:59) ~[d-node.jar:?]
at com.pega.dsm.dnode.util.PrpcRunnable.execute(PrpcRunnable.java:67) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.prpc.service.ServiceHelper$2.run(ServiceHelper.java:286) ~[d-node.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1397) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1140) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:947) ~[prprivate-session.jar:?]
at com.pega.dsm.dnode.impl.prpc.service.ServiceHelper.executeInPrpcContextInternal(ServiceHelper.java:279) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.prpc.service.ServiceHelper.executeInPrpcContext(ServiceHelper.java:145) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.dataflow.service.servicepulse.PartitionCreator.createFor(PartitionCreator.java:59) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.dataflow.service.servicepulse.RunInitializationTask.preparePartitions(RunInitializationTask.java:173) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.dataflow.service.servicepulse.RunInitializationTask.asyncExecution(RunInitializationTask.java:123) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.dataflow.service.servicepulse.AsyncAssignedTask$1.run(AsyncAssignedTask.java:69) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.dataflow.service.servicepulse.AsyncAssignedTask$1.run(AsyncAssignedTask.java:58) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.prpc.service.ServiceHelper.executeInPrpcContextInternal(ServiceHelper.java:296) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.dataflow.service.servicepulse.AsyncAssignedTask.lambda$tryToExecuteInLock$0(AsyncAssignedTask.java:58) ~[d-node.jar:?]
at com.google.common.util.concurrent.TrustedListenableFutureTask$TrustedFutureInterruptibleTask.runInterruptibly(TrustedListenableFutureTask.java:108) ~[guava-19.0.jar:?]
at com.google.common.util.concurrent.InterruptibleTask.run(InterruptibleTask.java:41) ~[guava-19.0.jar:?]
at com.google.common.util.concurrent.TrustedListenableFutureTask.run(TrustedListenableFutureTask.java:77) ~[guava-19.0.jar:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) ~[?:1.8.0_151]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) ~[?:1.8.0_151]
at com.pega.dsm.dnode.util.PrpcRunnable$1.run(PrpcRunnable.java:59) ~[d-node.jar:?]
at com.pega.dsm.dnode.util.PrpcRunnable$1.run(PrpcRunnable.java:56) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.prpc.PrpcThreadFactory$PrpcThread.run(PrpcThreadFactory.java:124) ~[d-node.jar:?]
Caused by: java.util.concurrent.ExecutionException: com.pega.fnx.stream.spi.StreamServiceException: Invalid configuration. Undefined stream provider end point.
at java.util.concurrent.CompletableFuture.reportGet(Unknown Source) ~[?:1.8.0_151]
at java.util.concurrent.CompletableFuture.get(Unknown Source) ~[?:1.8.0_151]
at com.pega.dsm.dnode.impl.dataset.stream.StreamPartitioningFeature$1.emit(StreamPartitioningFeature.java:134) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.stream.DataObservableImpl$SafeDataSubscriber.subscribe(DataObservableImpl.java:353) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.stream.DataObservableImpl.subscribe(DataObservableImpl.java:55) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.stream.DataObservableImpl.await(DataObservableImpl.java:117) ~[d-node.jar:?]
... 31 more
Caused by: com.pega.fnx.stream.spi.StreamServiceException: Invalid configuration. Undefined stream provider end point.
at com.pega.fnx.stream.spi.impl.kafka.KafkaSettingsProvider.getBootstrapServers(KafkaSettingsProvider.java:157) ~[?:?]
at com.pega.fnx.stream.spi.impl.kafka.KafkaSettingsProvider.defaultAdminClientProperties(KafkaSettingsProvider.java:93) ~[?:?]
at com.pega.fnx.stream.spi.impl.kafka.KafkaSettingsProvider.getDefaultAdminClientProperties(KafkaSettingsProvider.java:75) ~[?:?]
at com.pega.fnx.stream.spi.impl.kafka.KafkaServerImpl.getAdminClient(KafkaServerImpl.java:60) ~[?:?]
at com.pega.fnx.stream.spi.impl.processor.create.CreateStreamRequestProcessor.createTopic(CreateStreamRequestProcessor.java:64) ~[?:?]
at com.pega.fnx.stream.spi.impl.processor.create.CreateStreamRequestProcessor.lambda$execute$0(CreateStreamRequestProcessor.java:56) ~[?:?]
at java.util.concurrent.CompletableFuture$AsyncSupply.run(Unknown Source) ~[?:1.8.0_151]
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [?:1.8.0_151]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [?:1.8.0_151]
at java.lang.Thread.run(Unknown Source) [?:1.8.0_151]
