Queue Processor - Kafka folder structure
Can you please suggest for below question regarding Queue Processor rule.
If we create queue processor rule on multi node cluster (ex: Background Processing = 5 Nodes ), on which node the Kafka topic (physical folder structure) will get created?
Will it setup on all nodes of cluster? Or only on specific one node? If answer is specific one node then where to specify the configuration for desired node.
Thanks in advance.
