Rabobank
Last activity: 14 Sep 2021 8:06 EDT
How to configure a Facebook Ads Use Case In Pega 8.5.1?
We are currently in Pega v8.5.1. We have a Pega marketing setup in place and working and are trying to do a POC on Facebook Paid Media Ads. We have already established a successful integration with Facebook by adding the destination.
Can someone please explain the detailed step by step process to post Ads to Facebook? I mean what are the artifacts that we need to configure step by step. Till now we have done the following steps after successfully establishing the Facebook destination:
1) Configure the paid destination in Next Best Action Designer.
2) Create a simple Paid strategy with Proposition import and results(in the NBAD itself).
3) Enable a particular action for Paid channel.
4) Enable all the Paid media related agents.
I have gone through loads of articles on PDN but none of them explain the end to end configuration setup.
Chiranjeet Mishra
@ChiranjeetM5260 As far as I understand, it is not necessary to enable the paid synchronization for a segment that is used as the starting population for next best action. The starting population segment is not sent to the ad platform directly, but rather used as a starting point for the strategy to select the next best action.
Segment synchronization is a good starting point to test the synchronization without configuring the more advanced use cases. You only need to configure the destination (https://community.pega.com/knowledgebase/articles/pega-customer-decision-hub-implementation-guide/85/configuring-facebook-ads-destinations) and enable paid sync on the segment itself, then run the segment (https://community.pega.com/knowledgebase/articles/pega-customer-decision-hub-user-guide/85/enabling-segment-updates-paid-destinations). You do not need to enable actions for paid or run campaigns. After the segment runs, you can verify the results on the Audiences page, or in the destination platform, where you should now have a paid audience based on the segment.
A more advanced Paid use case is using next-best-action to generate audiences for specific actions, and communicating those audiences to destination platforms. The process is as you described above, except it doesn't require that you enable segment synchronization for the starting population segment (@moryh please correct me if I'm wrong here!). You configure the destination (https://community.pega.com/knowledgebase/articles/pega-customer-decision-hub-implementation-guide/85/configuring-facebook-ads-destinations), configure Next-Best-Action Designer (https://community.pega.com/knowledgebase/articles/pega-customer-decision-hub-user-guide/85/triggering-paid-updates-through-next-best-action), ensure you have some actions that are enabled for paid (https://community.pega.com/knowledgebase/articles/pega-customer-decision-hub-user-guide/85/enabling-actions-paid-channels), optionally specify if you want the synch to create campaigns in the paid destination (https://community.pega.com/knowledgebase/articles/pega-customer-decision-hub-user-guide/85/streamlining-campaign-generation-next-best-action-paid-audiences), then trigger the paid run e.g. through a schedule (https://community.pega.com/knowledgebase/articles/pega-customer-decision-hub-user-guide/85/configuring-recurring-schedule-next-best-action).
I would suggest that you first test the basic, segment-based synchronization and verify that it works before enabling paid schedules. This should make it easier to troubleshoot in case of errors.
Best regards,
Katarzyna
