CBA
How to change the type of the fled
I a trying to change the type of the filed of an existing property but not ball to change.
I tried deleting and creating the new one with same name but not working, PFA
***Edited by Moderator Marissa to change type from Pega Academy to Product, update Platform Capability tags****
Updated: 14 Jun 2021 7:38 EDT
I have created a property in 01-01-05 --- I want to withdraw
Created the same property in the new RSV- 01-01-06 and make it' available will it work?
Yes, this will work.
IQZ Systems
Hi
Even though you have deleted the field here, there would be a property rule already been created for that field with specific type.
Goto Records >> Data Model >> Property in Dev Studio
Open the property rule and delete the property.
You will then be able add new field with new type.
Sam mk
CBA
If I delete the present/existing Property will it impact where this property is already configured as Text?
On creating the new type of property will it get picked up/replace the old one? please let me know.
You need to delete the property rule, if you don't have the option to delete it, you need to withdraw the property rule and create a new property with the same name and select the Type in the above version of the withdrawn rule.
Sam mk
CBA
Once I withdraw, can I create the new property in the same RSV with the same name or I need to create in the new rsv?
After withdrawing, you need to create in the new RSV.
CBA
Major or minor -?
I think a new patch version should work. If it's needed we can go with either Minor or Major.
Updated: 27 May 2020 1:42 EDT
CBA
I did some snippet and found the below content, based on that I think we can move to minor version but again the examples Alpha DELTA make bit confuse
The examples given in the link are more confusing
Using a withdrawn rule to move a rule to another RuleSet
You can use the Withdrawn setting to move a rule from one RuleSet to another that is lower on your RuleSet list. This move is possible even if the RuleSet or RuleSet version containing the rule you plan to move is locked.
For example, assume that rule FOO is in RuleSet Delta:02-10-15 but you later determine that the rule is of broader applicability and belongs in Alpha:02-01-07, where RuleSet Alpha:02-01 is a prerequisite of Delta:02-10. In some cases, you can first delete FOO from Delta and then retype the rule into Alpha, but such deleting and re-entering isn't possible if Delta:02-10-15 is locked. Assuming Delta:02-10-20 and Alpha:02-01-07 are the current RuleSet Versions, to move the FOO rule:
- Open the rule to be moved.
- Use the Save As toolbar button to copy the rule into Delta:02-10-20.
- Set the Availability of the copy to
Withdrawn. Both Delta rules are no invisible to rule resolution - Use the Save As toolbar button to copy the original rule into Alpha:02-01-07. Set the Availability of this copy to
Yes.
The Delta:02-10-15 rule is now never selected by rule resolution, but every user who formerly accessed the Delta:02-10-15 rule now can execute the Alpha copy (unless rule resolution finds another rule earlier).
https://community.pega.com/sites/default/files/help_v71/definitions/w/withdrawnrule.htm
