TCS
Last activity: 22 Nov 2022 8:17 EST
how can we update the dashboard so that it should reflect to all users, instead of doing personlization ?
how can we update the dashboard so that it should reflect to all users, instead of doing personlization.
If suppose we need to add a widget to display for the users.
Infosys
You can customize the dashboard as per your requirement and add this dashboard to which users needed this dashboard. So that it will reflect all the users.
TCS
Can you please give more idea for customizing the dashboard as a developer.
Infosys
If you want to add any actions on dashboard or you can customize or rearrange existing actions in dashboard.
Adept View
To share the dashboard with all users.
Click Publish to default button after adding the extra widget in the dashboard.
This option is available for developers who can check out rules.
Your changes are seen only by users who have not yet personalized their dashboard. You cannot use the Publish to default option to globally reset a dashboard for all users in your application.
Thanks.
TCS
Can you please tell where exactly we can find the publish to default button and the rule name for adding the extra widget to display in the dashboard.
Adept View
TCS
I don't see any difference when I click on publish to default option.
Accenture
SG
Whenever you publish the dashboard, Pega internally will create a instance of System-User-Dashboard, please delete the instance of the user that you are checking and try to publish again.
Please refer the below link.
Vinay
Phavithra Vuyala Srinivasan Visweswara Rao Sikhakolli
