Standard Chartered Bank
Posted: Nov 23, 2015
Last activity: Apr 19, 2017
Last activity: 19 Apr 2017 9:28 EDT
How can I refresh the clipboard in Pega script in offline mobility application?
Hi Siva,
I assume you are using 7.1.8 or above? Are you asking for a custom script to sync the client with the server? I am not sure what business requirement you are trying to achieve, but this should help get you started regarding offline and typical syncing behavior.
https://collaborate.pega.com/question/offline-mobility-portal-header-synched-syching-offline
