How can I execute a shell script from Pega?
I have a requirement where I need to execute a shell script from Pega. This shell script exists on the Pega server/box and takes multiple(5-five) parameters. I have found below piece of Java Code on this forum which has been accepted as correct answer. But when I am trying to use this for my requirement I face below problems or have below questions. Any help is most appreciated
Clarifications needed for below Code:
1. When I try to save this code as is in Java step in an activity I get - "File cannot be resolved to a type"
2. In the 1st line as I see the name of the shell script and arguments are being passed. As in my case the script takes 5 parameters. How should I pass these? And what about the sequence of parameters?
3. Also I did not understand below part. What do I need to add to the Map env?
Map<String, String> env = pb.environment();
env.put("VAR1", "myValue");
env.remove("OTHERVAR");
env.put("VAR2", env.get("VAR1") + "suffix");
Piece of Java code found on this forum:
ProcessBuilder pb = new ProcessBuilder("myshellScript.sh", "myArg1", "myArg2");
pb.directory(new File("myDir"));
Process p = pb.start();
PS- I am using Pega 7.3. Let me know if any more details are needed.
