How can I mitigate Pega Robotics Studio's episodic latency?
I wasn't sure if I should submit these as separate questions, but they may ultimately be related or provide insight into the issues.
On a day to day basis, I experience a lot of latency when it comes to developing in Pega Robotics Studio and I am hoping to understand the cause of the latency, and am wondering if there are any settings or practices I can incorporate to minimise lag. I realise a certain amount of latency will be dependent on the system specs, but hopefully someone may be able to offer insight.
For instance, opening solutions can take several minutes. I notice that it always tries to reopen the solution with the previously visited automations already open, which may be a source of the lag. When I delete the .vs folder within a solution, it opens in Studio quite quickly, without loading/opening any automations. Is there a setting I can edit to achieve the same effect, without manually deleting the folder each time?
When closing tabbed automations that have been opened, there's a very significant delay (especially if I ask Studio to close more than one (i.e. right-click Close all Documents). This can lead to 5-10 minutes where Studio stops responding while it tries to close 5 or so tabs. What causes this delay, and is there any way to reduce it?
I've noticed delay even when adding automation links between components, where Studio will seem to not respond for several seconds, and then suddenly incorporate the new link. This feels like it should be a relatively process-light task, are there any suggesting to what could cause this delay?
Finally, I notice it saves the zoom level/position for each automation file. Is it possible to disable this?
I'm hoping to understand if there are any general reasons for these latency issues that I might then address, or if there are any steps I can take to mitigate these issues.
Thanks in advance!
