Evonsys
How to attach an inbound email to the work object?
Need to attach email to the work object, what activities is there that can be used for this?
PEG
May I know how are creating work objects? Incase if you are using Email Listener to create work object you can use pyCreateAndManageWorkFromEmail OOB activity to create and attach mail to work item.
Refer https://community.pega.com/sites/default/files/help_v72/procomhelpmain.htm
TCS
SA
Work object is already created and our requirement is to update the inbound email as an attachment to the existing work object. Could you provide any suggestions ?
Thanks in Advance !!
Matheswaran Ravichandran
Synechron Inc
Is there a way we can modify the EML file before attaching it to the WO. I have a requirement to modify the subject line of the incoming email before attaching it to the WO. Any thoughts?
Merkle Inc
Yes you can modify the subject.The subject will be saved in the properties which you are using in the request.In my case i am using the ".pyInboundEmail.pySubject".Before attaching the attachement you can modify the subject and save it on the page with the class of Data-Corr-Email and use link-objects method to add the email attachment to the WO.
Infosys
If work object is already created then apart from the configuration specified by Praneeth, you also need to get the attachment (original email) from pyAttachmentPage (page created as part of EmailListener processing) and link it to work object.
Murali...
Souradeep Bhuniya
AdeptView
Is there any leads to change the original-email.eml file in to pdf?
