HookChildProcess does not work on windows adapter
Hi Teams,
I created a Windows Adapter and defined an application to be started by a command from a batch file, but the element of the application cannot be recognized.
The definition is as follows.
Path: Full path of batch file (c:\xxxx\....\xxx.bat)
Target Path: Command started from batch file (cmd /c start /min c:\xxxx\....\xxx.exe xxx.unc)
HookChildProcess: True
StartMethod: Start
StartOnProjectStart: False
When I Start Interrogation, the batch file is started, but it seems that Interrogation ends without waiting for the start of the child process.
Is there a good solution?
Environment:
OS : Windows10 Enterprise(10.0.17763)
Studio Proprietary information hidden
Best Regards,
