To Highlight the Dropdown Dynamically
I have a screen ,, now there are 2 column , in one column there is a drop-down which is getting populated via a data page..
And there is a second column where data is getting populated from the RPA bot,,
Now , if in that column from where data is coming from the bot is not matched with the values of other drop-down , then that drop-down which is getting populated from the data page , should get highlighted ,, so that it looks like the user should select the value from the data page drop-down then only it can move forward...
Main Issue is to highlight the dropdown, other things can also be acheived by OOTB Functionality
