Areteans Technology
Last activity: 18 Feb 2016 12:38 EST
Hi, When i am going to start pega it is not being started only getting the below, could any one please help?
server starting
Using CATALINA_BASE: "C:\PRPCPersonalEdition/tomcat"
Using CATALINA_HOME: "C:\PRPCPersonalEdition/tomcat"
Using CATALINA_TMPDIR: "C:\PRPCPersonalEdition/tomcat\temp"
Using JRE_HOME: "C:\PRPCPersonalEdition\jre1.7.0_45"
Using CLASSPATH: "C:\PRPCPersonalEdition/tomcat\bin\bootstrap.jar;C:\PRPCP
ersonalEdition/tomcat\bin\tomcat-juli.jar"
Hi Ashwani,
Have you setup ANT_HOME in your system's environment variable?
Updated: 17 Feb 2016 13:55 EST
Areteans Technology
Yes Arvind,
Do I have to remove it ?
No, its required, just see if its correctly set.
Do you have log file, except the one paste above; can you please share that?
Areteans Technology
Hi Arvind,
Tomcat didn't start therefore no any log file generated in logs.
Ashwani,
Can you please play around memory settings in setenv.bat file present in Tomcat/bin folder to see Tomcat starts properly.
Areteans Technology
Arvind,
The below details are in this file (setenv.bat), please assist if any thing needs to be changed in this?
rem Change -Xmx value based on available physical memory
rem -- This is for JMX support
rem
set JRE_HOME=C:\PRPCPersonalEdition\jre1.7.0_45
set JAVA_OPTS=-Xms1024m -Xmx1024m -XX:PermSize=64m -XX:MaxPermSize=384m
Can you take backup of this file?
and replace set JAVA_OPTS arguemtns with below:
set JAVA_OPTS=-Xms768m -Xmx899m -XX:PermSize=128m -XX:MaxPermSize=256m
Areteans Technology
Arvind,
Now It is running fine after replacing line (set JAVA_OPTS=-Xms768m -Xmx899m -XX:PermSize=128m -XX:MaxPermSize=256m).
Thank you so much for your help.
If possible could you please elaborate the work of this line?
Ashwani,
This sets the memory related argument for Tomcat.
Sometime, tomcat does not handle more heap memory allocated to it and hence, crashes.
Areteans Technology
Ok, Thank you
