Hi I am facing below error while Installing Pega7 in my machine..
BUILD FAILED
I:\Pega\PegaPearsonEdition_V7.1\114898_PE719\pegaGuiInstallerTemp11\build.xml:191: The following error occurred while executing this line:
I:\Pega\PegaPearsonEdition_V7.1\114898_PE719\pegaGuiInstallerTemp11\build.xml:75: exec returned: 1
Total time: 1 minute 19 seconds
org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again
at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:89)
at org.tp23.antinstaller.runtime.ExecInstall.exec(ExecInstall.java:87)
at org.tp23.antinstaller.selfextract.SelfExtractor.main(SelfExtractor.java:398)
Caused by: org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again
at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:79)
... 2 more
--- Nested Exception ---
Please help.
