Hi I am getting below error while Installing Pega7
BUILD FAILED
I:\Pega\PegaPearsonEdition_V7.1\114898_PE719\pegaGuiInstallerTemp6\build.xml:157: Unable to connect to database within 15 seconds.
Total time: 1 minute 23 seconds
org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again
at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:89)
at org.tp23.antinstaller.runtime.ExecInstall.exec(ExecInstall.java:87)
at org.tp23.antinstaller.selfextract.SelfExtractor.main(SelfExtractor.java:398)
Caused by: org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again
at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:79)
... 2 more
--- Nested Exception ---
Message was edited by: Lochana to add Categories
