Having a test application showing inaccurate guardrail warnings in trunk
Recently I saw a presentation that having a QA (test) application in our application stack is a best practice. Attached.
i.e. Dev/branch application is built on QA/test application, which is built on Prod/trunk application.
In this model, we noticed that the trunk application showing inaccurate guardrail warnings and % compliant score. Even if there are valid test cases defined, the rules merged to trunk still show this warning:
You should create a test case for this rule to identify any regression issues that might occur when this rule is modified. |
This is probably because the test cases are merged to the test application, which is not visible to the trunk application.
Is there any solution for this or work around?
