Evonsys Pvt Ltd
LK
Last activity: 12 Feb 2018 10:12 EST
Guardrail warning
I get this guardrail warning. Can someone explain this??
"Using a custom HTML control to format a column may result in poor performance displaying query results. Consider using auto-generated HTML controls"
***Updated by moderator: Marissa to close post***
JP
If you don't use your custom HTML, please check Auto-Generated HTML on HTML tab.
Evonsys Pvt Ltd
LK
This warning is displayed on the report definition. It does not have any HTML tab. Other sections' HTML are auto generated.
JP
How about your property in column on the report definition.
Does it reference customized UI control on property definition form?
Areteans Technology
check format in RD for columns included.
Evonsys Pvt Ltd
LK
When I remove the date property from the RD and include it again, the warning disappeares.
Virtusa
Worked for me too, but removing all the columns and adding is tedious as we have lot of default DataTableEditorReport created by Pega.
Anyways thanks for the input :)
Incessant Technologies
This is a default Warning appear with existing report definition rules. If you have saved as the report from an existing report (which is exist in the old version) the warning will be appear.
Solution:
1- Save as your report in a different name and delete the earlier report.
2- Please create a new report from app or record explorer.
3- Copy your steps or required changes from the report (save as report) manually.
4- And save the report.
Solution:
The warning we will be removed. Please check and let know us.
Sumita
If you are facing this Warning in the Report Definition try this step as well :-
In the QUERY tab -> Goto the Setting (Options) -> there you will have "column Format" in that some control will be there like "pzKeyInput".
Just remove it as it cause performance issue. and Save your Rule once again . Your Warnings will be eliminated. :)
Hcl Technologies BV
Thanks.. It is working for me :)
JP Morgan Chase
Is a list of all Guardrail warnings available?
Guardrails are Instances of Message rule..
