Telstra
Handle Aged Updates in deployment using prpcServiceUtils
In Pega 7.2.2, when we use prpcServiceUtils for deployment, aged updates are going in and replacing newer rules. Is there a way to handle that from command line utils? I found an article (link below) which says "No" but it was for 7.1.8 but I wanted to check if it's still the same for Pega 7.2.2
https://pdn.pega.com/support-articles/aged-updates-does-not-work-import-mode-command-line
Checked the code, does look like you are right, no changes even for 7.2.2 - i.e., no such support for the command line. I will double check with SMEs and confirm when I get a chance unless someone else replies with definite answer.
