Google chrome Extention
GOOD DAY.
I am developing an RPA for a web page, in the development I use the Pega Chrome extension and a web adapter, but I have issues because sometime the BOT doesn't recognize the elements on the web page, manually I delete the temporary “AppData \ Local \ OpenSpan \ 8.0 \ Projects”, run the BOT again and ran without issues.
This issue repite in different computers.
PEGA version: 8.02025.0
PEGA Chrome Extension: 1.0.86
@NiyiredC I suspect your issue is with the Chrome extension not being enabled or properly registered. Whenever you start Chrome (assuming it is the first Chrome process started), you should see a new process started named "OpenSpan.Translators.Web.MessagingHost.exe". If this isn't coming up, then you would not be able to see any controls. You would get an error message though. I am not sure why deleting the extract directory would matter to Chrome. It might just be the restart that is helping there rather than actually clearing that folder. You might need to get some hands-on assistance by raising a support case. If you do, please note the case number here so we can add any resolution.
