Virtusa
Last activity: 8 Feb 2017 9:48 EST
Getting deadlock on lock resources
Did anyone face this kind of issue before? We are seeing this kind of exceptions in the logs. We got around 100 - 150 exceptions at once. Below is the exceptions details -
2017-01-05 17:00:25,976 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ PegaRULES:07.10] ( internal.access.DatabaseImpl) ERROR - Encountered problem when performing a Commit
com.pega.pegarules.pub.database.DatabaseException: Database-General Problem saving instance of class Log-RuleUsage-Details 1205 40001 Transaction (Process ID 657) was deadlocked on lock resources with another process and has been chosen as the deadlock victim. Rerun the transaction.
SQL: MERGE INTO dbo.pr4_log_rule_usage_details t USING (VALUES (? , ? , ? , ? , ? , ? , ? , ? , ? , ? , ? , ?)) AS inputs ("pzInsKey" , "pxAssemblyCacheKey" , "pxClassName" , "pxCreateDateTime" , "pxDetailIndex" , "pxInsName" , "pxObjClass" , "pxParentRuleUsageKey" , "pxSystemNode" , "pxUpdateDateTime" , "pxUseCount" , "pyLabel") ON (t.pzInsKey = inputs."pzInsKey") WHEN MATCHED THEN UPDATE SET pxAssemblyCacheKey = inputs."pxAssemblyCacheKey" , pxClassName = inputs."pxClassName" , pxCreateDateTime = inputs."pxCreateDateTime" , pxDetailIndex = inputs."pxDetailIndex" , pxInsName = inputs."pxInsName" , pxObjClass = inputs."pxObjClass" , pxParentRuleUsageKey = inputs."pxParentRuleUsageKey" , pxSystemNode = inputs."pxSystemNode" , pxUpdateDateTime = inputs."pxUpdateDateTime" , pxUseCount = inputs."pxUseCount" , pyLabel = inputs."pyLabel" , pxCommitDateTime = CURRENT_TIMESTAMP WHEN NOT MATCHED THEN INSERT (pzInsKey , pxCommitDateTime , pxAssemblyCacheKey , pxClassName , pxCreateDateTime , pxDetailIndex , pxInsName , pxObjClass , pxParentRuleUsageKey , pxSystemNode , pxUpdateDateTime , pxUseCount , pyLabel) VALUES (inputs."pzInsKey" , CURRENT_TIMESTAMP , inputs."pxAssemblyCacheKey" , inputs."pxClassName" , inputs."pxCreateDateTime" , inputs."pxDetailIndex" , inputs."pxInsName" , inputs."pxObjClass" , inputs."pxParentRuleUsageKey" , inputs."pxSystemNode" , inputs."pxUpdateDateTime" , inputs."pxUseCount" , inputs."pyLabel");
SQL Inserts: <LOG-RULEUSAGE-DETAILS E23452A54252F8DE4B878B91AA81BD79!COM.PEGARULES.GENERATED.HTML_PARAGRAPH.RA_STREAM_PZACTIONSETLABEL_CF98ACC33973C9B6016E2BB3D324EAA6!RECENT!0> <RULE-HTML-PARAGRAPH|EMBED-CONTROL-MODE-ACTIONSETS!PZACTIONSETLABEL;STREAM|IMS:Administrators!Prod!01.10.01$1830589c08e58ed6372d90c24c853b3b> <com.pegarules.generated.html_paragraph.ra_stream_pzactionsetlabel_cf98acc33973c9b6016e2bb3d324eaa6> <2017-01-05 17:00:03.375> <0> <E23452A54252F8DE4B878B91AA81BD79!COM.PEGARULES.GENERATED.HTML_PARAGRAPH.RA_STREAM_PZACTIONSETLABEL_CF98ACC33973C9B6016E2BB3D324EAA6!RECENT!0> <Log-RuleUsage-Details> <LOG-RULEUSAGE E23452A54252F8DE4B878B91AA81BD79!COM.PEGARULES.GENERATED.HTML_PARAGRAPH.RA_STREAM_PZACTIONSETLABEL_CF98ACC33973C9B6016E2BB3D324EAA6!RECENT> <e23452a54252f8de4b878b91aa81bd79> <2017-01-05 17:00:03.375> <3> <recent>
Caused by SQL Problems.
Problem #1, SQLState 40001, Error code 1205: com.microsoft.sqlserver.jdbc.SQLServerException: Transaction (Process ID 657) was deadlocked on lock resources with another process and has been chosen as the deadlock victim. Rerun the transaction.
at com.pega.pegarules.data.internal.access.ExceptionInformation.createExceptionDueToDBFailure(ExceptionInformation.java:257)
at com.pega.pegarules.data.internal.access.Saver.addBatch(Saver.java:980)
at com.pega.pegarules.data.internal.access.Saver.saveInstance(Saver.java:796)
at com.pega.pegarules.data.internal.access.Committer.performOps(Committer.java:236)
at com.pega.pegarules.data.internal.access.DatabaseImpl.attemptToProcessUpdates(DatabaseImpl.java:2625)
at com.pega.pegarules.data.internal.access.DatabaseImpl.processUpdates(DatabaseImpl.java:2288)
at com.pega.pegarules.data.internal.access.DatabaseImpl.commit(DatabaseImpl.java:2027)
at com.pega.pegarules.monitor.internal.context.RuleUsageImpl.updateSnapshot(RuleUsageImpl.java:339)
at com.pega.pegarules.session.internal.mgmt.Executable.updateRuleUsageSnapshot(Executable.java:7867)
at com.pegarules.generated.activity.ra_action_ruleusagesnapshot_8acf7559930ab416e0609201cc19c6af.step1_circum0(ra_action_ruleusagesnapshot_8acf7559930ab416e0609201cc19c6af.java:177)
at com.pegarules.generated.activity.ra_action_ruleusagesnapshot_8acf7559930ab416e0609201cc19c6af.perform(ra_action_ruleusagesnapshot_8acf7559930ab416e0609201cc19c6af.java:69)
at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3375)
at com.pega.pegarules.session.internal.async.agent.QueueProcessor.runActivity(QueueProcessor.java:719)
at com.pega.pegarules.session.internal.async.agent.QueueProcessor.execute(QueueProcessor.java:600)
at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:885)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1177)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:926)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:825)
at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:618)
at com.pega.jsr166backport.java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:991)
at com.pega.jsr166backport.java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:532)
at java.lang.Thread.run(Thread.java:744)
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: Transaction (Process ID 657) was deadlocked on lock resources with another process and has been chosen as the deadlock victim. Rerun the transaction.
at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDatabaseError(SQLServerException.java:216)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.getNextResult(SQLServerStatement.java:1515)
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.doExecutePreparedStatement(SQLServerPreparedStatement.java:404)
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement$PrepStmtExecCmd.doExecute(SQLServerPreparedStatement.java:350)
at com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:5696)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(SQLServerConnection.java:1715)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeCommand(SQLServerStatement.java:180)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeStatement(SQLServerStatement.java:155)
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.executeUpdate(SQLServerPreparedStatement.java:314)
at org.apache.tomcat.dbcp.dbcp.DelegatingPreparedStatement.executeUpdate(DelegatingPreparedStatement.java:105)
at com.pega.pegarules.data.internal.access.DatabasePreparedStatementImpl.executeUpdate(DatabasePreparedStatementImpl.java:471)
at com.pega.pegarules.data.internal.access.Saver.addBatch(Saver.java:956)
... 20 more
***Updated by moderator: Lochan to update Categories; added SR Details***
